Few Hub Questions???
I need to ask a few questions about the 250es.
1- On the 85, the front hub and brake drum are a two piece attatchment There are 2 countersunk screws and if you undo them it will lift right off. On the 87 it doesnt have those 2 screws and it doesnt look like the drum will seperate from the hub. Is this a 1 piece unit or does the drum come off another way?
2- I want to use the 2 peice drum/hub but the axel is stuck in the hub. Would it be able to be pressed out?
3- How would i get the bearings and races out of the front hub?
Thanks in advance,
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
