200x probs update.
After I was advised to check the fuel flow because my bike would start and idle but not go far, I did. Here's what I discovered. When turned to regular, fuel barely trickles out of the petcock. When on reserve, it pours like it should. So that's one problem. The other problem is that when it's on reserve it was flooding. I leaned it out, to start, and that still didn't do it, so I added a fuel filter (it didn't have one) to slow the flow a bit. That did it well enough to get it running, and I took it for several laps around the field and it didn't die at all. But if I push it, it starts to flood. Where do I go from here? A smaller jet? If it would make any difference, the seal/gasket between the bowl and the rest of the carb is missing, but I don't know how that would effect it.
It ain't no fun unless you kin git hurt doin it.
Rides: YTM-225DX, 2x YTM-175, KLT-160, ATC-125M, ATC-250SX, ATC-200x, ATC-200E
