Results 1 to 2 of 2
Thread: 250r gaskets
    nate b is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central WI
    433
    250r gaskets
    need some advise on gaskets for my 85. I had the motor redone about 10 yearago and have only put about 15 hours on it. anti freeze is starting to seep out the head gasket. Im gona pull the top end. what brand gaskets do you guys recomend, and do you run any special thickness. also should i do the crank seals too.
    85 atc 250r;
    PSI porting & head mods
    fmf pipe & silencer
    boysen rad valve & reeds
    38mm air stryker
    Apr 2004
    Upstate NY
    102
    For that i would recomend a oem gasket
