is it possible? will a 200x front tire and rim work with a 350x hub????????
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
hey, been there done that, the bolt pattern is the same, but the studs, and the wheels are different. 200x has 8m/m studs, plane wheel. 350x has 10m/m studs, steel inserts in wheel. later
one cylinder is not enough!!
so i need to put in spacers in the wheel?
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
a 86 200x is the same hole pattern,, but a 83-85 200x hub is not the same hole patern,,, its wider,,,
Just been thru that as well. My 85 200x wheel would not fit the 350x hub, so I had to use the 350x wheel. Can't remember, but it seemed I couldn't switch the hubs either. I ended up using all the 350x stuff.
