Thread: 350x, neutral problems, need help
    Dec 2003
    Ontario, Canada
    235
    Well i went riding the other day for 8 hours straight, as the day went on Neutral was harder and harder to get it in to, if it was running, i could shut it off and it would click right in, i was doubling all day but dont think that should make much difference, what is my cause of neutral being a trailprotrailprotrailprotrailprotrailpro to find.
    ps it goes into when ever i dont really need it like when i park it, but if i am riding and need to get off for like 30 sec it never wants to go into it, this is on my 86 350x with suprap exhaust, thanks for any help
    1986 452x, 4inch westcoast swinger, full exhaust, and stage 5 racing kit
    99 honda 300 4x4
    06 Forman 500 4x4
    07 Fourtrax 420 FI
    Previous rides
    81 250r, 83 Cr 250, 85 250 big red, 80 185, 84 200s, 83 KLT 200, 86 Alt 185, 01 WR 250, 83 250r, 84 250r, 1986 350x, 1985 350x, 87 350x, 91 big bear, 01 DS 650, 03 Kodiak 450.
    Rittman, Ohio
    6,276
    Your problem is caused by clutch drag. When you pull the clutch lever to release the clutch, there is still friction, and its not releasing all the way. This can be caused by grooves in clutch basket, poor oil, lack of oil, or too heavy of an oil. If oil is too heavy, problem wont be as bad when motor is hot. If it gets worse when its hot, its one of the other 3. Contrary to popular opinion, crappy oil does not cause clutch slippage. It causes a clutch to not slip when its supposed to, as in, when you pull the lever.
    One band aid is to slip it into neutral while its still rolling, and before it comes to stop.
    Dec 2003
    Ontario, Canada
    235
    hey thanks man, I will change the oil tomorow night and hopefully that helps out, and i will adjust my clutch cable
    99 honda 300 4x4
    06 Forman 500 4x4
    07 Fourtrax 420 FI
    Previous rides
    Apr 2003
    HARTFORD CT, USA
    478
    Make sure your clutch/cable is adjusted correctly.
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    Ashland City, TN
    2,576
    Didn't you see that he said he was going to adjust it in the post just above yours?
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Quote Originally Posted by packhamstruck
    I doubt the oil change will help it - most likely with it being a 350CC thumper your looking at clutch basket grooves as Tim has posted.
    Dec 2003
    Ontario, Canada
    235
    Well got some good news, the oil was very black, lost track of how many hours I put on that machine, and she had lots with that oil, now with the new oil and filter, neutral seems to be 80 % easier to find, in the last 2 hours i only had troubles once, and i didn;t adjust the cable i will do that some other time, what do i all need to replace if i do have to put a clutch in it, i have never had to on any machines thanks.
    ps funny how this starter after i let some girls drive it
    99 honda 300 4x4
    06 Forman 500 4x4
    07 Fourtrax 420 FI
    Previous rides
