will 200x hubs fit on my 200s
Won't work. Your 200S will take hubs from an 81-5 110, an 84-5 125m, an 82-3 185S, an84-5 200S, and an 82 250R.
and 86 125m
The 200x hubs will fit on the 200s axle. How ever they are a different bolt pattern, so you won't be able to use the 200s rims.Originally Posted by thehickfarmer
Now if your looking to put 200x hubs and 200x rims on a 200s then you will be fine.
Howdy
Howdy,
Should any year 200x work? I am planning on putting a set on my 185s and have some extra SX wheels and tires that I plan on running. There is a guy here locally that has a set of 83-85.
86-87 Tecate ROCK!
All years 200X are the same as well as 250x 300EX which extend the axle width about 2".
The 83-85 200x hubs will fit on the 185s with no problem. How ever if your going to install 250sx rims on them you will need to remove the studs and grind the little locator "nubs" off of the hubs. If you don't remove these "nubs" ( as I call them ) the rim will not seat on the hub properly and could lead to a accident. Nobody wants that.Originally Posted by ScottZJ
The Locator "Nubs" are the old style design on the Honda's. They used these "Nubs" on the 200x until they switched over to the cone style lug nuts ( 1986 ). Once they switched over the "Nubs" were no longer needed unless your running the 83-85 style 200x rims.
Let me clarrify TimSr's post here a little ( Sorry Buddy, lol ). To be a little more specific: Using 83-85 200x hubs should give you a stock width ( or close to it ).Originally Posted by TimSr
If your looking to add a little width, then use a set of 86-87 200x hubs or a set of rear hubs off of a 250x ( TimSr knows more on that model ), 300ex, 400ex. NOTE: These style hubs will not have to be modified for the 250sx rims.
Scott, One more thing you might not know. Try putting your Tecate hubs on the 185s. I had a 87 Tecate and those hubs fit right on a 200x axle. Tecate tires and rims would make a 185s really look custom.![]()
Howdy
please tell me the bolt pattern on the 2oox is 130mm , cuzz then i can get the maxxis max lite 8 spoke rims![]()
The 200x uses a 4/110 mm bolt pattern.Originally Posted by thehickfarmer
Howdy
ohhhh thats right, the 200s takes 130 right
There are a lot more rim styles available for the 4/110 pattern as its probably the most widely used pattern, a lot more common than 4/130, and used by almost all of the Hondas after 85, as well as several other makes. If you want to stick with the 4/130 bolt pattern, in addition to the older Honda hubs mentioned early in this post, Suzuki LT230 hubs will fit and use the 4/130 bolt pattern. 84-85 200s is 4/130.
well i'm gonna go with howdy, if he says the 200x hubs will fit then i'm gonna go with him, and their are these beauty rims i seen on www.maxxis.com , their called maxlite 8 spokes, their so damn nice, and their bolt pattern is 110 by 4![]()
Your post above stated that these spokes you wanted were in 4/130.Originally Posted by thehickfarmer
We are all in agreement that 200x hubs will fit your axle, and you will then have a 4/110 bolt pattern.
i'm lost now, but i got the info i need, lol so i'm in agrement to , lol
Hey I just happen to have a set on the way to me as we speak!! Haha I just need to snag those wheels out there now to make it work.Originally Posted by Howdy
86-87 Tecate ROCK!
