Thread: Big Red Shifting rough.
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Got a question guys when im on flat ground the bike shifts great. However when im going up and down these georgia hills it drags somewhat between gears. Shifts kinda hard. Harder to get from 1st to 2nd etc... Dont get me wrong its not real hard to shift. However it is much stiffer to shift than my SX on the same hills. Do you think the play in the clutch is to tight? I ajusted it last night and so far havent had a chance to run it. What do you guys think?
    Clay
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Moncton Newbrunswick,Canada
    509
    could be a bent or worn shift fork.
    NE Arkansas
    2,344
    I searched and found this old thread that relates to mine.
    My 85 Red is doing similar things. Not bad, just annoying at times. Sometimes it's difficult to come out of reverse, and go from 1st to 2nd. I've found that it's smoother if I have shift from reverse to neutral with the trike rolling a bit. It's smoother from 1st to 2nd if I shift while letting off of the throttle just a little not completely. I too have tried adjusting the clutch without success.
    Any help is appreciated,
    Travis
    My Rags
    Sep 2006
    S.E. LA
    700
    Well I'm actually having a similar problem with my '80 110. I just had the right side cover off and the shift fork, gears, everything looked just fine and actually still looked like new.
    My problem is mainly downshifting. It shifts fine going through 3rd, but coming back down and getting back in neutral is kind of a pain. I just got it running pretty much so I haven't rode it a lot. I did have to shift it back in neutral with my hand instead of my foot a few times.
    By the way the tranny is in LOW. Haven't had a chance to run it in High.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
