Hello,
I have a question about a 1984 atc 200x. What is the newest motor, of the same size that would bolt right into the frame?
Thanks for all the help.![]()
atc 777
john
Hello,
atc 777
john
the 1985 is the same
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
You know what, I saw some chinese enduro on e-bay with a honda engine in it, and was looking at it. It sure looks damn close. It would be cool if it worked. It kicks the wrong way, but it has elecric start.
the engine in that enduro could be an xr200 maybe? did they have electric start?
1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
1984 Honda 200ES
198? Yamaha YT60 Tri-Zinger
TrikeFest '04 & '07 Survivor
Didn't the xr 200 engine come in the 86-87 200x? Besides this engine has a 5-speed trans. I'm sure the xr has a 6 speed.
Would the XR 200 Motor fit the 84 200x frame, or would I need to modify the frame? Thanks again for all the help.![]()
they are the same motor just 6 gears and you have to change the kickstarter to kick forward.
1982 250r it will run again, new rings,razors,stator!!!(UGLY)
1985 200x runs on race fuel or alky ONLY!
western new york riders check out:
http://groups.yahoo.com/group/wny3wheelernuts/
How hard is it to change the kick starter to kick forward on these motors?
Thanks![]()
John
86-87 200xs had 6 speed transmissions. You could maby even fit a 250cc motor in there. Maby a cr![]()
they are east to change if you have a 200x kickstart assembly
a buddy of mine has a 78 xl250, and the motor looks like it might almost bolt into a 200x
Caution
Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
