I've got everything I need to do the swap and just realized that the headlight mount is NOT the same. The headlight on my '82 110 (square) has mounts coming out from the fork which meet the headlight on the sides. A bolt on each side goes directly through the fork and into the side of the headlight. The fork from the 125m ('84) doesn't have the protruding mounts. The holes for the headlight are "flat" against the fork. Does it use some kind of mounting bracket to adapt into the sides of the headlight?
