Thread: 200x gettin to much gas what do i do?
    Oswego, IL
    1,858
    what should i do if my 85 200x is gettin tooooooo much gas. it is leaking out from the bottom the bowl or whatever . it is were you are suppose to have a drain hose but i dont got one. it is leaking a lot out of there
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    JoeSuzuki's Avatar
    JoeSuzuki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Ontario Canada
    172
    ajust the float screw inside the carb
    Still learning how to use and abuse my toys.
    Columbus Nebraska
    138
    Maybe you forgot to close the screw? Otherweise it usually doesn't leak out of that little drain, cause on my S when it was flooded i allways turned off the gas, opened that screw and drained all the gas out if it, turned the gas back on and it popped off, so i don't think it should be coming out of there.
    1985 ATC 200S--no spark, parts for sale
    85 YTM 125--needs a carb cleaning and set up
    79 Suzuki TC125--dirtbike, now fully restored!
    84 ATC 200x--Need a good frame, rear caliper bracket, and a blown up or barley running motor with a good clutch.
    Message me if your interested or have anything i need
    Nov 2002
    Buffalo, NY
    142
    Take your carb off, and give it a good cleaning, your float valve is probably sticking, or may need to be adjusted...What year 200x? Does it have a fully plastic float, or is the "tang" on the float metal?
    2004 Kdx200
    2005 sv650s
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    As i recall ALL years of the 200X's had the plastic floats. 83-87 24mm carb. Correct height would be 14mm
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
