Would 85-85 R fork boots fit on 83-85 200x's?
I might be able to get a pair, and save me a few bucks rather then buying them from a shop.
thanks
Jon
thanks
Jon
Caution
Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
xr250 fork boots fit pretty good, I'm gonna put them on mine. you can get fork boots from msr.
I wouldn't see why not.
R.I.P Raven
2006 Yamaha Banshee Special Edition
1996 Honda CBR 600 F3
The fork boots from an 83-84 250R would work but the 85/86 250R forks were much larger in diameter than your 200X. I guess the ones from the 85R might work but it would be sloppy. Bythe way the 83-84 250R forks area larger diameter also but only by 2mm.
Curtis.
I love anything with an engine except a lawnmower...
1986 Tecate and original owner of a 1985 200X.
3 wheeling since 1975.
