Results 1 to 4 of 4
Thread: Do 250r fork boots fit on 200x????
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    Would 85-85 R fork boots fit on 83-85 200x's?
    I might be able to get a pair, and save me a few bucks rather then buying them from a shop.
    thanks
    Jon
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Jun 2003
    englishtown NJ
    2,676
    xr250 fork boots fit pretty good, I'm gonna put them on mine. you can get fork boots from msr.
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    I wouldn't see why not.
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    The fork boots from an 83-84 250R would work but the 85/86 250R forks were much larger in diameter than your 200X. I guess the ones from the 85R might work but it would be sloppy. Bythe way the 83-84 250R forks area larger diameter also but only by 2mm.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
