Results 1 to 11 of 11
Thread: 86 SX problem
    kyle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2003
    291
    86 SX problem
    My 1986 Honda 250SX and I were out in the woods today and the rear tires locked up on me. The engine was still running fine but it wouldnt go. The only way it would move was if I gave it a lot of throttle it would go, but something is binding or something. Any suggestions on what it may be would be great. I dont want to tear into it right away until I get some ideas what to look for. Thanks, Kyle
    1986 Honda 250SX
    eh_tee_see's Avatar
    eh_tee_see is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bristol Bay Alaska
    295
    maybe your differential blew out... ran out of fluid??? if thats what happened that sucks.. i could sell you one maybe. and it could be your brakes though unlikely it could be stuck.
    The below sentence is TRUE.
    The above sentence is FALSE
    Mar 2003
    Australia
    1,919
    Sounds to me like your brakes have locked up. Ifthe diff ran out of oil it would still be able to turn im sure....
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Ashland City, TN
    2,576
    Yes, if it ran out of fluid it would still turn. Even if it was bone dry in there, it would still turn. Like Matt said, sounds like the brakes locked up. One way to find up: put the rear end up on blocks, completely loosen(or take off) the brakes, and see if it turns easy. If it does, take it off the blocks and go for a little test ride and see how it works. Later
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Apr 2003
    291
    The 1st thing I checked was the diff, I pulled the fill plug and the fluid was full and looked to be ok, no chunks and the oil didnt look silver. I then pulled the boot off of the drive shaft too see what I could, everything from what I could see looked to be ok. It didnt really sound like it was my brakes, it sounded kinda " clunky " thats why I thought it was the diff or driveshaft. But I am going to check the brakes anyway cause thats not a very hard thing to do. Thanks for the ideas! Kyle.
    1986 Honda 250SX
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    I would pull the brake drum cover of to be sure. Sometimes the brake pads actually come off the shoe and jam up against the drum. My best guess would be the brakes are locked up somehow.
    Good Luck and keep us posted
    P.S
    How did you get it homw with the rear end locked up?
    Apr 2003
    291
    The tires didnt lock up completely, i just had to on the throttle for it to move, so i limped her back to the barn that way. I had it out today and she seemed to be rolling fine. Im thinking it was the brakes now. Kinda weird. But i still need to take it appart and check.
    1986 Honda 250SX
    Mar 2003
    Australia
    1,919
    You shouldent have rode it back mate. Your brakes will be worn out now or if they came of the pivot point your brake drum and or linings will be scratched up. Hope they arent though.
    Matt
    Apr 2003
    291
    I really had no other choice. I was the only one out there and I was about 2miles from the barn.
    1986 Honda 250SX
    yater is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2003
    Tyler, Texas
    672
    rear brake is locking up. Try throwing it in reverse and then forward again and it usually lets go. Just adjust them. It's happened to me too.
    May 2003
    Shediac, New Brunswick
    1,126
    MAYBE if you pay howdy he will give you his info on what he thinks it is :Evil
    '04 450r, hr +3 stroker, s2 hotcam
    '84 Honda 200x
    slow restro
    Previous rides 82 Yamaha yt175, 85 Yamaha 225DR, 84 Honda 200M, Ski-doo Olympic 340
