Results 1 to 11 of 11
Thread: tri-z problem
    Watertown, New York 13601
    3,382
    tri-z problem
    On my 85 z there is a gas line or something that goes into the cylinder on the right side and a little metal elbow. What is that elbow?? mine is loose and leaking gas. How do i fix this problem??
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    That is the vacume line for the fuel pump. If its got fuel leaking out I'd say the fuel pump needs chunked or rebuilt.
    YAMAHA_Jim's Avatar
    YAMAHA_Jim is offline 4 Motos, 3 Wheels, 2 Classes, 1st Place Arm chair racerJust too addicted
    Apr 2003
    Rock Hill,NY
    1,000
    Absolutely what billy said.the cylinder pumps air to work the diaphram.
    3,382
    How does that little elbow thingy that goes into the cylinder cause the pump to need rebuilding?? That little elbow is loose in the side of the cylinder and is leaking. Is their anyway to tighten it or is it just worn out? What is the name of this part so i can get a new one. Thanks
    2006 YFZ 450
    Live Oak, FL
    15,069
    Its not suppose to have fuel in it, at all, ever. That elbow creates a pressure from the cylinder that operates the fuel pump. If there is fuel leaking out of the elbow, either a line is crossed or the fuel pump is fubar and needs repaired/replaced. I've never had one come loose...but I think its probably just pressed into the cylinder. If thats the case then something must have hit it to knock it loose. Atleast thats what seems logical to me.
    Rittman, Ohio
    6,276
    Tap it into the cylinder with a . (Lightly, dont whack it!) I just pulled one out of one cylinder and put it into another.
    Do NOT reconnect the hose to it!
    As others have said, that is a vacuum line that operates the fuel pump. it should NEVER have gas in it. If it does, it means your fuel pump diaphram leaks, and is probably cracked, and its dumping gas right into the bottom of your crank. You will need to take apart the fuel pump, and replace any cracked or leaking components.
    3,382
    Quote Originally Posted by TimSr
    Well there is gas in the vacum line so now how do i fix or rebuild the fuel pump? Do they make kits? where can i get one?
    2006 YFZ 450
    GreenBoy is offline At The Back Of The Pack Arm chair racerFirst time rider
    N/A
    189
    Here is your rebuild kit......
    Fuel pump rebuild kit
    One of those kits should solve your problem, maybe such a kit is available from your Yamaha dealer.Check the partsfishes on www.yamaha-motor.com
    Hope this helps
    Hagen
    TF ´03
    TF ´04
    TF ´05
    TF ´06
    US Trip ´08
    US Trip ´09
    US Trip ´10
    US Trip ´11
    US Trip ´12
    US Trip ´13
    US Trip ´16 yet to come
    3,382
    Quote Originally Posted by GreenBoy
    Hope this helps
    Hagen
    Will this kit work?
    http://www.bikebandit.com/partsbandi...dept_id=811764
    2006 YFZ 450
    Front royal, va
    2,186
    no,it wont the pump on the z is round ,those gaskets are square,i used scott google tear off lens cut to the size of the two outer gaskets in the pump and after one year is still pumps fine with NO LEAKS!!!
    Feb 2003
    southwestern NY
    641
    Be sure to change your oil when your done with the rebuild.If it sucked gas into the lower end you will wash all the oil down and ruin the motor.
