Results 1 to 7 of 7
Thread: 1985 atc 250r... Question..asap....
    Sep 2003
    79
    guys,
    I might trade my 200x plus 300 bucks for this 250r.
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=7901996912
    the guy said it leaks oil from a seal...
    does need seal where clutch goes into case has small leak
    is that gonna be a major fix or a simple one?
    thanks
    -Jim
    02 raptor
    01 lakota sport
    85/86 tri-z
    Cincinnati, OH
    3,289
    if he is talking about the seal were the arm goes in easy fix! etheir way i would trade!!!
    sandrooster is offline At The Back Of The Pack Arm chair racerFirst time rider
    mom's house
    193
    Very simple.
    You just need to get a new clutch cover gasket and new seal.
    85 ATC250R
    Dec 2002
    SW Alabama
    764
    That is not a big deal to fix. Just gat a manual and you should not have any probs. Looks like a killer deal to me.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Mar 2004
    minnesota
    22
    I would do it!! looks like a good deal...the 250r is a kicking machine!! I just stuck close to 700 dollars into mine, did the work myself..it took a while but man...they are fun machines!
    C W. is offline First Time Rider Arm chair racerNew to the board
    Apr 2004
    Key Largo FL.
    107
    a clutch release arm seal leak aint nothin it doesent realy even leak.you check your oil every tank and change it every good ride.maby just a little dampness there but its a easy fix any way.i would look for more emediate trouble.like brakes ,bearings,rear shock acting like a pogo stick,and just plane ugly cracked riped and faded.the motor should realy blow your thumb off of the spark plug hole to.and feel good and strong when you kick it.be weary of some one who would get rid of a 250R for a thumper.
    Rittman, Ohio
    6,276
    Quote Originally Posted by C W.
    Yes, and im a little curious as to why its even mentioned. The purpose of this seal is not to keep oil in, but to keep things like water OUT. If oil is actually coming out of that seal Id be very surprised. Id look very closely to determine where the oil leak is REALLY coming from if there is one.
