Rear carrier rebuild
I'm rebuilding the rear end of my honda 200, I insalled a grease fitting and new bearings. The problem is the new bearings, I think I seated them too deeply. The spacer in the middle now turns with the inner bearings- you spin one bearing and the spacer spins the other. do I have to back out the bearings? Will it loosen up on its own?
dont wory about it.let it rip.
The spacer is suppost to move with the bearings. You said it was so that means you did it correctly.
Howdy
Non-problem, I like that. Thanks for the info. When I tore it apart the spacer was all over the place, so I thought it was suppposed to be loose. Thanks again.
//ArrowChat Integreation Code
