Thanks to the board for reccomending the right magneto puller for my honda 200. With the magneto out the way I could see the problem, the cam chain tensior is trashed- not the plastic part but the metal arm on the bottom. I think the chain fell and got caught on the smaller part of the tension arm. I took off the mangled piece and noticed a crack on the mount underneath, a little finger pressure and the boss popped off the case in two pieces! So I ask you is it parts or can that be fixed? I noticed the spot for the boss is still several mil deep, could I tap it and get a longer bolt or maybe put a stud in the hole?
