Thread: tri z crank seals
    Apr 2003
    141
    tri z crank seals
    do you think you can go a couple times of pulling the crank before changing seals or should you do it every time. i know you "should" do it every time, but, just wondering.
    Leaks, Leaks, Leaks! Why does it always have to leak!http://www.3wheelerworldforums.com/viewtopic.php?t=11559
    C W. is offline First Time Rider Arm chair racerNew to the board
    Apr 2004
    Key Largo FL.
    107
    Thumbs down don't want to know
    You make spliting the case sound like a oil change or spark plug change how often are you in there.I hate it in there it ain't worth nobody finding out the hard way.Do your self a favor and when you get seals get two sets for the old girl.
    Apr 2003
    141
    well its not that i do it that often but i do like to keep fair tabs on things and i have done it alot of times. i can pull the motor in under thirty minutes now, so its no biggy!
    Apr 2004
    Key Largo FL.
    107
    Wfo
    My crazy motor head budy i grew up with. used to build all kind of dirt bikes and n!@@$# rigs.He died last year in his damn 327 5 speed powerd S10.He would say slap it together it'l work.Just look at them you can tell.
