Thread: 350x rear brake caliper
    Mar 2004
    18
    i need to know how to rebuild the rear caliper on a 86 x. or if one from like a 400ex or other will fit.
    Mar 2004
    18
    bump.......
    Cincinnati, OH
    3,289
    is it still working, just leak or what? if its just the o rings take it apart go to store buy o rings or if its the pistons are bad then just get another caliper!
    Ddw350's Avatar
    Ddw350 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    mine was sticking awhile ago,i played hell with it for months! finally i tore the hole thing down cleaned the heck out of it,put it together and works fine.the problem was that the piston would push out but there was so much corrosion on it ,it wouldnt return,it stayed out and gradually went back in,causing the brakes to drag.its seems fine now
    Mar 2004
    18
    just sticking and toasting pads
