Need help with Suzuki LT 250 Quadracer
Hey guys, I just traded for a 1988 Suzuki LT250r Quadracer and it has a few problems I need help with. Ok, when you first start it (cold) it will idle fine but if you ride it for like 2 mins it will just shut off when it comes to a stop. The idle adjustment screw is all the way in. Next problem; it seems like it has a half-throttle rev limiter. When in neutral you can hold it wide open and it will just cut out and start whining like a waa-waa-waa-waa but you know, its not really wide open (not screaming), like its wanting to stay at half throttle and it smokes alot when its doing that. Its kinda hard to explain but I'm doing the best I can.
It will do it all through the gears too, except for fifth and then it revs real high, then bogs down, then revs high, bogs down and repeats itself over and over. Right now it is runnnig a pretty much a straight pipe. The silencer is completely bare (all the insides taken out) and the end cap is off. Very LOUD!!!
BTW, I got it like this. Could this cause not enough restriction resulting in power loss?? Could it be the reeds? It doesn't bog during the first half of throttle, just the second half and it has awesome accelleration. There is no popping during decelleration either. I'm ordering a new FMF pipe and silencer this weekend but need ideas to what the problem could also be. Thanks!!
Justin ~hondaATCman~
'82 Honda ATC 110
'81 Honda ATC 250r (Summer Project)
'87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
'03 Yamaha Big Bear 400 4x4
'85 Ford Bronco II 4x4 2.8 V6
