hi my z flutuates its revs when its on tick over!!
cinda like: rrrRRrrRrrRrrRRRrrrR
lol now i feel like a twit!!
anyways any idea what the problem is?
it also does it when i'm deaccelerating down hills!!
cheers
nipps
cheers
nipps
Rides:
86 Tri z phase 1 wrench report porting n DG pipe (this beast is what really got me into trikes!!)
84 honda 200 big red
84 yamaha 225dx
"To scrout or be scrouted the question remains!!?"
It sounds like an air leak. Check the boot from the cylnder to the carb. Spray some WD-40 around the boot when the trike is running. See if the revs go up.
Also while the trike is running push the carb from side to side. Usually a tear in the boot will open up when you push the carb to one side. This will cause the revs to increase...thus you know you have an air leak.
You will be better off changing the boot anyway.
SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
