Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 44
Thread: Not your normal atc 70
    Minnesota
    784
    I just got this 70 Saturday. Need some help with it. Has anyone seen chain rollers like this before? The one is still there, but it appears that the lower one is gone. I'd like to find a replacement. Also, any idea what forks they are? The guy I got it from said as far as he could tell they are 185s forks? What are the things a few inches below the dust seals? They appear to be threaded holes of some sort, is this where a fender would attach or a front rack (if they are 185s forks). I think one of the forks is on backwards because the threaded holes are pointing the same way. What is the phillips screw for towards the bottom of the fork? What year 70's uses 3 lug hubs, and had phillips screws for the case bolts? It is a 3 speed.
    Apr 2003
    Bay Area CA.
    2,638
    thats a kick azz 70, but those aint to no 185s forks
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    That is a very cool 70 Hrc. How does it run?
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Minnesota
    784
    He said the carb, cyclinder, head, piston was all brand new. I belive him on the carb because the screws are still gold. It sure doesn't want to idle though. It starts first pull, but then after warm somtimes it will idle really high, and other times it will die. The rear suspension actually is very soft, and functions better than I thought it would. With the open air filter you can really hear the air being sucked into the carb.
    the forks usually used in a suspension 70 are from an xr motorcycle. all honda 70's are 3 lug. 3 speed is 81 or older. wanna sell it?
    Kevin©
    I love the smell of race gas in the morning®
    my pics
    Man i love it!
    1983 Honda 110
    1967 Mustang
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    that looks awesome. how fast do 70's go? that looks like it'd be fun to play around on
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by hrc200x
    Those forks are aftermarket. I have a set very similar to them. The difference is they were off a bigger machine. If you look at the fork bottoms you will see a Suzuki mark on them. This is the "S" that they use for their parts.
    The chain tensioner is a good one. The metal is chrome plated with what seems to be roller skating wheels on it. I know this because like the forks I have one of these also. I have never even thought about selling it. I am saving it for the one machine I am getting started on ( real soon, I hope ). If your missing a wheel you might want to go garage sale shopping for a pair of old roller skates. You could also go to a local roller rink and get one. I'm 80-90% sure they will work or can be slightly modified to work. And it would be easier to find in the future.
    Howdy
    Dec 2002
    749
    Thats an awesome 70! Id love to have one of the chain tensioners. Youll have alot of fun with that.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    jason200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    i have 3 wheels with good bearings in them. let me know if you need some.
    Makes me wanna build a monster 70 to!
    1983 Honda 110
    1967 Mustang
    Clarks Summit PA
    1,236
    i was looking at that one for a bit.. the guy never wanted to ship it.. but i didnt want to take the ride for it... good deal!
    Ride it like you stole it! And never look back! They are too far behind to see!
    you could probably use a chain roller from a newr dirt bike, like a crf450 or somthin
    Kevin©
    my pics
    Minnesota
    784
    skippy, this is the actual one you were looking at? Where did the guy live?
    May 2004
    New Zealand
    129
    I run a skateboard wheel on my chopper as a chain tensioner and as long as you have a good, high rpm pair of bearings, they last for years. Any urethane wheel will work perfectly. Make sure you don't use a cheap plastic one....I tried one of those and when the bearings heated up on a long ride, the inner wheel melted - not good.
    The great thing about skateboard wheels is the color range...pick one out to suit the trike.
    Andy
