Results 1 to 2 of 2
Thread: 83-85/86 200x motor
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    83-85/86 200x motor
    Someone told me they had an 86 motor in an 85 frame. does it bolt right in? I know the motor looks a bit different but are the mounts the same? I know the innards aren't interchangeable
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Oswego, IL
    1,858
    no they do not bolt up.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
