Results 1 to 7 of 7
Thread: first mod for 350X
    Apr 2004
    92
    first mod for 350X
    hey guys , i was wonderin what could be my first mod for my 85 350X i was thinkin the 393cc kit by powroll, maybe sum bolt ons? idk , j/w
    fast trikes , BIG jumps, hot women, what else is there??
    SOLD-85 350x -roostboost ignition,uni-airfilter. You will be missed
    Apr 2003
    Bay Area CA.
    2,638
    tires, filter, pipe?
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
    Nov 2001
    B.C.
    933
    As mine came with a DG pipe, my very first go-fast part was a Wiseco 10.25-1 piston.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Apr 2004
    92
    was that a kit or did you just bore the sleve out n buy the pistons n rings?
    Nov 2001
    B.C.
    933
    As there was some scarring to the cylinder from a dropped valve, the cyl. was bored to the first oversize, honed and a new piston and ring set was dropped in. Just a basic bore and piston! Really simple.
    Apr 2004
    92
    i thought just borin it , it didnt give it much HP , well its probably why cheaper just buyin the piston and ring and havin my uncle bore the sleeve for free (he has a borein machine)
    Roanoke, VA
    4,038
    Supertrapp Exhaust, 372 or 390 bore (stroker), Aftermarket cam (White Bros has one I think), Heavy Duty clutch (Kevlar), and a 10.5:1 or 11:1 piston.
    My brother has a 350X motor stuffed into a TRX250R frame and it RIPS! He's got a 372 stroker kit, cam, 11:1 piston, rod, and a heavy duty clutch kit. It will pull wheelies in 5th gear with me on it....it kicks trailprotrailprotrailprotrailprotrailpro
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
