Thread: KLT 110A exhaust
    Jun 2004
    USA, Massachusetts
    5
    Klt 110a Help!!!
    anyone know where i can get a New pipe (not the slip on) for my 84 KLT 110A the pipe on there now is old and has a couple of leaks eventhough its louder with them and pisses my neighbores off very easily i need a new one
    also does anyone know how to get a foot brake back on i bottomed out on a stump with it :o could i drill through n bolt it?
    Also when i pin the gas it will bog down and stall unless you let go and try again
    and another problem does anyone have any suggestions of a stripped shifter input shaft because a new one wont even fit its so stripped down could i maybe drill through and bolt the shifter on?
    trying to get this beast in top running shape
    Jun 2004
    perris ca/lake elsinore
    101
    when it bogs its probully the carb you just need to rebuild it or clean it out
    new york
    5
    same problems with mine
    Quote Originally Posted by camarozz2828
    mine does the same so i got the parts offr ebay
    Baltimore, MD
    6,088
    The shift pedals and shift shafts you can still get through the dealer, I had to put one on a 1984 klt110 that I had. I also bought a new tank from the dealer, less than $100. I'm not sure what you mean when you say the brake pedal, is it broken off? What is the problem, be more specific please. To remove the shifter shaft and replace, you must remove the right side case cover and remove the clutch pack and the shifter shaft fits behind there and it goes all the way through the other side of the case. The dealer and ebay were both good sources of nos parts. Good luck.
