Thread: I need a new piston for my 185s.Options?
    StangLX302's Avatar
    StangLX302 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    302
    Question I need a new piston for my 185s.Options?
    Well, my poor 3 wheeler has been smoking for a few months now and now it barely even runs. It's time for an over haul. I want a piston that will bump my compression up a bit. I don't mind running race gas if I had to. I can get race gas all over town here.
    What are my options? Anyone make anything for maybe between 10 and 11 to 1 compression? How much can I SAFELY bore a 185s over? What is a fair price to pay for the bore job?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -Air filter box removed
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    -200s front forks/shocks
    -Aftermarket 4 bolt rear wheels
    -Tire chains when ice riding
    1988 Ford Mustang LX 5.0L
    -Wayyyy too much to list!!!
    Nov 2001
    B.C.
    933
    Go with a Wiseco 10.25:1 piston, and anly bore it enough to clean up the cyl. wall. Any more of a bore is just wasting future cyl. life.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    StangLX302's Avatar
    Jun 2003
    302
    I was just checking out Weisco web site and you basically have to use a standard sized 200s piston and bore it .080" over. Would that be OK?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
    Nov 2001
    B.C.
    933
    Don't overbore unless the cylinder is so bad that it must be done. Have you tryed looking at Pro-X pistons yet?
    I looked at the Wiseco site, and they are listing only a 200cc piston as a 185 replacement. You may have to go with just a normal comp. 185 piston, OR pick up a good 200cc jug and go that route.
    Another option is to buy a Honda 200X piston rather than an aftermarket unit. I did a 200cc machine recently, and the Honda parts were cheaper!
    StangLX302's Avatar
    Jun 2003
    302
    Quote Originally Posted by Mobular
    That will just bolt on without changing anything else?
    1981 Honda ATC 185s
    -DG Exhaust
    -200x Carb
    -Uni Filter
    -10T Front Sprocket
    -Plastic fuel tank
    -Aftermarket seat
