Results 1 to 11 of 11
Thread: 125m problems
    Jun 2004
    Middle of Nowhere
    18
    125m problems
    Is there a way i can tighten the clutch on a 125m? i tightened the nut on the side cover all the way down, it drives but it slips when i give it gas....
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    The way you adjust the clutch on it is as follows. First get a open end box end wrench. I use the open end and loosen the nut ( to the left ). Some times the threaded bolt with the slot moves with the nut so put a screw drive in the slot to keep it from moving. After the nut is loose, turn the threaded part with the slot to the left until it bottoms out or stops turning. Now turn it back to the right a 1/4 turn. Stop and Get the wrench and tighten the nut. Keep in mind that the threaded bolt with the slot for the screwdriver may want to turn so put your screwdriver on it to hold it in place. Hold it in place and tighten the nut down snug. The clutch should be properly adjusted then. Tightening the nut just holds the adjuster in place. Try it. If it still slips your clutches may be very worn. Hope this helps.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Jun 2004
    Middle of Nowhere
    18
    the slotted screw is all the way screwed to the right, i can't go any farther....i have 2 clutches and the do the same thing
    Mar 2004
    1,727
    Yes I uderstand, but that slotted screw should be much much more over to the left. You are saying its all the way to the right. It shouldnt be. It should be all the way to the left. All the way. Then turn it to the Right a quarter turn. If im not mistaken all the way to the right will make the clutches real loose. All the way to the right will make it tight as hell. Wont even go into gear. Or if it does it wont shift out. This is how I adjust my trikes clutch per the honda service manual. ATC 70, 250SX, & 250 Big Red. My Big Red was shifting real stiff a month ago. So I went thru this procedure. When it was all said and done the slotted screw was further to the left than when I started. Hince it shifts like a champ now.
    Clay
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Jun 2004
    Middle of Nowhere
    18
    it still slips all the way to the left....il'e try to find another clutch, thanks for the help
    Jun 2004
    Middle of Nowhere
    18
    i see in your signature you have a gutted 125m...still have the clutch for it?
    Mar 2004
    1,727
    No, all I have left is a good looking gas tank, footpegs, cdi box, starter relay/solinoid, forks assembly, frame, and front axle assembly. Thats it. Oh and wheels too. No tires.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Jun 2004
    Middle of Nowhere
    18
    i found out that clutch slips only when the engine gets hot...cuz when i park for the night, the next day i start her up and it does'nt slip for like 15 mins...any idea what causes that?
    Mar 2004
    1,727
    Maybe the clutch is worn a bit and when the oil warms up it get thinner and that causes the slippage. Maybe you should drain a little oil and add some STP additive to it and see what it does. Not the whole bottle. but maybe 30% of it and see what gives. I know that oil can have an affect on wet clutches. What type of oil do you have in it. Weight? Synthetic?
    Clay
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    Nov 2002
    1,189
    To adjust the clutch, you loosen the nut, and turn the inside screw conterclockwise. It should get to a spot of resistance. Then turn the screw clockwise 1/4 of a turn. this adjustment only adjusts the clutch when you shift. When you shift, this clutch is activated by the shifter, and allows it to shift easier. if you screw it too far counterclockwise, the clutch will always be disengaged, and will slip. If this is adjusted right, and it still slips, your centrifugal clutch is worn out. Put it in 2nd and gas it. If the motor wants to revs, but then it seems like it has stopped revving, but the machine is still accelerating, then that is a sign that your clutch is going.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Jun 2004
    Middle of Nowhere
    18
    im running Castrol 10 30, not synthetic
