Thread: 84 250r oil check bolt/help
    Jun 2004
    Ca Northcoast/Redwood coast
    68
    Question 84 250r oil check bolt/help
    The small oil check bolt on my 84r does not thread in well. I think the threads on the engine part are damaged, I bought a new bolt and it still vibrates off at high speeds and it does not tighten up well. How can I remedy this? Thank you gentlemen for your time.
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    I would first drain the oil out then take the side cover off the trike and tap the hole one size larger. Then buy a new bolt. Possibly with a lock washer on it to keep it from working itself loose .
    Thats what i would do..
    Chris
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    Dec 2002
    SW Alabama
    764
    You could also have a shop helicoil the hole. This will let you use the stock size.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Dec 2002
    Kansas
    2,387
    My 85R had this same problem. The hole was pretty much totally stripped out. I just taped the hole out to a 5/16 size and it works perfectly. Cheap repair also.
    I had the RIGHT to remain silent, I didn't have the ability!
