Results 1 to 8 of 8
Thread: Rear YTM Noise
    May 2004
    Slatington Pa.
    17
    Rear YTM Noise
    My YTM 225 project is going pretty well, the only problem is I have a weird clunking noise coming from the rear. It is not when the machine is running, but when its shut off and I rock it from side to side. I think its comming from the swingarm. Any one have any input? I am also thinking about putting new plastic all around. Anyone know how much it would cost new, or have any leads on where I can find some in really good condition? Already looked on e-bay, no luck. Oh yea the pastic is blue.
    "MAD DOG LOST HIS WAY"
    Nov 2002
    1,189
    Look for the axle moving in and out of the carrier, or for the swingarm moving on the pin.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    Check out your u-joint
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    Nov 2002
    Northern Mi.
    516
    Oops, Also check the pivot shaft on both sides where the swingarm mounts for loose hardware or damage.There should be little black rubber covers that conceal them.Another thing it could be is rear axel bearings or ,less likely,it could just be your rear disc brake making noise.It's a floater disc so they all make noise.Good luck.
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    I would check your axle for play. Bearings could have gone bad. There are also swing arm bearings that could be causing this noise and of course the pins for the shock. If you can "rock" the machine from side to side, something is worn. It should be stiff and solid, i.e. no play.
    Anyone know of a new project machine for me around Wisconsin?
    Apr 2003
    HARTFORD CT, USA
    478
    Talking
    For plastic (blue) Check your dealer....its still available.
    I couldn't believe it myself, but its there. The stickers are a different story....
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
    May 2004
    Slatington Pa.
    17
    I didnt think they would have them. I guess I'll give them a try, Thanks
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I know where you can get plastis.
    From the yamaha dealer,OEM.Rear in sky blue plastic $99.99,Front fender $38.99,front headlight plastic $39.99.Side tank plastics discontinued.Front mud flap discontinued.I did a full restoration on my 85,check out my pics buy clicking on my avatar symble.Then you will see post started by edog.I also have plastic from when i restored it .It is in good shape.
