hey im have probles with a carb its poping snaping reving really hi fauling plugs and the throttle adjustment ant working please help.
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
try adjusting the idle pin and check the piolet if it is backwards
umm the pilot???
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
Allow me to translate:Originally Posted by threewheelin-feelin
Hey, I'm having PROBLEMS with a carb. It's POPPING, SNAPPING,AND REVVING really HIGH, FOULING plugs, and the throttle adjustment ISN'T working. Please help.
if its a two stroke it sounds like the cyl base gasget is leaking and sucking air..Did you pull the carb and check for plugged jets?
You must be fast,because I was hauling ass when I past you!
LMAO! Thanks. I wasnt sure whether poping was popping orOriginally Posted by Mobular
ing.
all 3. poping --you cant figure out what its sayin
popping--obvious
ing--fouls plugs and well,
s
Does it also go 'crackle' aside from the snapping and the popping?
its a 4 stroke 84 atc200s. billy said i need to tune the carb to post on how to do it.
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
Poping: That's what the guy with the big white hat, who lives in the Vatican does! He Popes....
ok......... that dosent help much but w/e![]()
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
Uh, just using YOUR word....
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
Spray something around the seals near the carb, and the head. If you use either (Sp??) you know, starting fluid, hehe, it will rev up for a bit. Also, check to see if your carb slide is going down the tube all the way.
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
WOW, I fell off my chair at that!Originally Posted by Mobular
Serioiusly though, check your timing as well as what was stated above.
Lots O Trikes!!!!!
ok ill try that
current rides
82' ATC110
85' ATC310R
85' ATC250R
85' ATC250ES
16' brute force 750
