Results 1 to 9 of 9
Thread: Push start
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Push start
    When I push start my YTM-200E(on gear), sometimes the engine turns and sometimes it don't. What is the problem?
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Jun 2004
    perris ca/lake elsinore
    101
    the engine is'nt getting any gas probully flooded sometimes and sometimes not
    TheOlderFox's Avatar
    TheOlderFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2003
    Black Creek, WI
    299
    Turns over or runs? If it is not turning over what gear are you puching it in? 5th is most effective. If you are talking about firing, you need to first figure out whether it is getting a good spark or not before chasing fuel problems.
    Anyone know of a new project machine for me around Wisconsin?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Yamada
    You didn't post what machine you have. But here is a little general info:
    On centrifical clutch models they have a part called "bearing-one way". This part will grip when turned going one way and it will slip when going the other way. If your motor spins over some times and don't other times then most likely this part has gone bad.
    If you post what Yamaha you have I will try to get you a picture of the possible problem area.
    Hope this helps.
    Howdy
    Jun 2003
    South of Rochester, NY
    3,471
    Howdy....
    Look in your "quote" you posted. I think it might be a YTM200E and from his signature, a 1984.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by 350x'inNY
    Howdy....
    Bruce
    ooops, I missed that!! 3 lashings with a wet noodle!! lol My only defence was that I had been up for 20 hours when I posted that. lol
    Howdy
    Apr 2004
    1,529
    It's not the 200E, but the YTM-200 1983. I tried on all five gears.
    Is the one way bearing on this picture?
    Howdy's Avatar
    Celina, Ohio
    10,079
    Yes, #19 is the part that would be going bad. They say to replace Part #18 also.
    Howdy
    Apr 2004
    1,529
    Thanks Howdy!
