Thread: YTM Wheels
    May 2004
    Slatington Pa.
    17
    YTM Wheels
    Can I fit a 20/11/8 tire on a stock 85 ytm225 wheel?
    Also is there supposed to be any play at all in the rear axle when you lift the rear off the ground and shake it back and forth? The key word here is ANY.
    "MAD DOG LOST HIS WAY"
    Jun 2003
    Lake George, New York
    1,732
    What's the size of the stock rim? And you probably need rear bearings...
    Josh
    May 2004
    Slatington Pa.
    17
    Dude your from the Aderondacks? I use to live in Lake Placid, Anyway Stock tires are 22/11/8. Are bearings hard to replace?
    Jun 2003
    South of Rochester, NY
    3,471
    Tires should work.... first number is the height. 2nd-width 3rd-rim dia.
    So basically to your rim, it will be the same tire..... just 2" shorter.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Nov 2002
    1,189
    Nor, there should be absolutely no play in the rear. Any wobble can mess it all up. The bearings can be a pain if you dont have all the right tools. A few could be made, for taking out the pinion and such...
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
