parts showed up..TECH QUESTION
on the LT230, how do you properly set the timing, when putting a motor together? It has no open port to view the flywheel to indicate TDC. I THINK if I put it to TDC, and install the cam and rocker cover so as the cam is not (obviously) operating a valve, (it wouldnt go together if it were, anyway) then it should run, correct?? anyone familiar with these motors?? I will be final assembly tomorrow.
Haspin veteran '02, '03, '04, '05
"Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
RECOVERING Trikeaholic
