Thread: rings or not? 300EX
    Apr 2004
    21
    rings or not?
    My 300ex is spitting out oil out of the vent tube (on top of motor).. i was told i probably cracked a ring. i pulled the moto apart and the rings look good. can you look at a ring and tell if its good. i pulled the rings off and they look good. any ideas? thanks
    Apr 2004
    21
    any one?
    Nov 2002
    1,189
    Did you take the piston out fo the jug? There is obviously too much blow-by, due to a bad seal, or a broken ring. When you compress the ring, they should just about touch. Just a reminder though, this is the trike forum! I'm sure more replies will be givin in Quad Central!
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Rittman, Ohio
    6,276
    With experience its often easy to visibly tell, but you can also measure ring end gap, and ring thickness, but youll need those specifications.
