im getting a 200x and id like to get info on it also is it a 4 or 2 stroke
It s a four stroke, 192 cc, 85 and older, with a 5 speed. 86/87 were 199cc with a 6 speed. Chain drive, about mid 50's top speed, Made by honda, of course. What else... Disk brakes all around, and air cooled. Also, 83-85 had a round frame, and 86-87 were square, which is the easiest way to tell the year (Except if the sticker is still on the frame.)![]()
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
that about sums it up.
Current rides:
85 Honda 200x -- For Sale
86 Honda 200x
79 Honda Z50 minibike
If speed kills......I'm a dead man!
the 85 had a box type swinger were as the earlier modles had a tubular swinger. they kick arse in the trails, ummm, very very easy to work on and are dependable. they go closer to 60mph. best trike out there lol
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
the more i read the more i want come on im hungry for more the one im gettin is a 83'
The 83 model had 191cc and the 84 to 85 had 192 and the 86 to 87 had 199cc
put an 85 swinger on there it is stronger
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
84 is the same, it was only the 83's that had the tubular swingers
Caution
Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
Frame number JH3TB0526DC263800~
Engine number TB05E-6000034~
Engine type 4 stroke, Air cooled
Displacement 192cc
Bore x Stroke 65 x 57.8 mm
Compression ratio 9.6 to 1
Compression 142 - 170 psi
Transmission speeds 5 speed
Clutch Type Manual
Oil Capacity 1.3 Qt
Carburetion 24 mm Keihin
Starting system Kick Starter
Fuel capacity 2.56 Gal , 0.31 Gal res.
Wheelbase 47.6 in.
Overall Length 72.8 in.
Overall Width 41.3 in.
Ground Clearance 4.9 in.
Seat height 27.8 in.
Front tire 23.5 x 8 x 11
Rear tires 22 x 11 x 8
Front suspension Hydraulic Telescoping Forks
Rear suspension Mono shock
Front brake Hydraulic Disk
Rear brake Hydraulic Disk
Final drive Chain
Dry weight 282.2 lbs
Approx. retail new $1,698.00
1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
1984 Honda 200ES
198? Yamaha YT60 Tri-Zinger
TrikeFest '04 & '07 Survivor
im a big guy were can i find a shock for the rear tat will hold me good
throw a 350x rear shock on there all u need is the shock and the part muddy200x is selling on ebay(helpin u out muddy lol) and for the front all u need to do is chnger the steering stop. im a big guy 10 about 6'5'' 200lbs and mine is good with the normal shock but it needs a lil more stiffness so im going to get one of thoes custom made parts from muddy. http://cgi.ebay.com/ebaymotors/ws/eB...483269062&rd=1
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
