my kick start got harder and harder to kick and 4 sec after that it wont budge whats goin on? help
Was your engine hot when that happened? Maybe she's siezed.
83 honda 200s![]()
83 honda 185s![]()
97 polaris 250 trail boss
yea she was hot i need help lol its a dirt bike me and my dad bought and i fixed it up and i drove it for bout 15 min and it killed so i kicked it and it was hard to do and i tried again and it dont move at ALL!!!
uh oh, was there the right amount of oil mixed with the gas? If it's liquid cooled was there enough coolant in there, will it move now after it's all cooled down. Kinda sounds seized to me.
I'm currently riding:
1984 honda110
1982 honda185s
1986 honda bigRed
1984 honda 250R-- .80 over, cobra expansion chamber, shaved head, decked cylinder, larger carb., carbon-fiber reeds, 18" carsliles, RK race chain, uni-filter.
1986 yamaha IT200
1985 yamaha XT250
1978 Italie Snark Moped
and some vintage dirtbike.
how do i fix that and it was full of oil maybe the oil injetor cloged it was full
well i've heard of oil injectors failing quite often, so that would be a good bet into what happenen. Have you tried turning it over since it's cooled?
1984 honda110
1982 honda185s
1986 honda bigRed
1986 yamaha IT200
1985 yamaha XT250
yea she wont budge
Sounds like it is seized. If you want to be sure you might try to yank off the mag cover and see if you can turn the engine from there. That would let you know if it was in the engine or tranny. It really sounds like engine probs though.
2000 Banshee: Modded out!!!
1985 ATC 250R: Bone stock but not for long.
1984 ATC 185S: Modded out!!
1979 ATC 110: Stock execept fork extentions
1984 ATC 110: Same as above
what do u mean take off the mag cover??? and how can i fix this?
The left side cover is used to seal the magneto from the weather. In the center of the magneto there is a nut. You can put a socket and ratchet on the nut to see of you can turn the engine from there. Don't put out so much that you twist off the crank though. If it is not seized it should turn over quit easy. If you can turn it then you know you have a tranny or kick start problem. If you cant turn it, it is in the engine. You might try to put a little WD-40 down the spark plug hole and work it back and forth from the mag side. Most of the time when they cool down they free up anyway.
take off the flywheel cover, and try to turn the flywheel. but if the engine is indeed seized, depending on severity of it, you'll probably need a bore job, piston, rings... possible crank, and rod bearings. basically a top-end overhaul.
1984 honda110
1982 honda185s
1986 honda bigRed
1986 yamaha IT200
1985 yamaha XT250
do u have any idea how much that would cost averagly
somewhere around $300 give or take a little
1984 honda110
1982 honda185s
1986 honda bigRed
1986 yamaha IT200
1985 yamaha XT250
What kind of bike is it?
1975 suzuki 100cc
