what is o good brand of pistion i can get for my 85 200x? i need an new pistion and rings. where shoudl i get it? and what brand? thanks jim
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
The most popula brand is going to be weisco. I prefer Pro-X pistons myself. They are not quit as hard as weisco's and tend to wear the piston instead of the cylinder itself. In the long run it will make it where you don't have as much of a demand to bore it per rebuild, generally just a fresh set of rings. Honda pistons are actually very good but they are pricey and I don't know if you can get em with a dome to increase the compression.
2000 Banshee: Modded out!!!
1985 ATC 250R: Bone stock but not for long.
1984 ATC 185S: Modded out!!
1979 ATC 110: Stock execept fork extentions
1984 ATC 110: Same as above
where can i get a Pro-X piston from? what about the pistion kits on ebay for like 59 bucks them any good?
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
Ebay has alot of good items but now is the time to decide if you want to run a stock compression piston or if you want to bump it up to a 12:1 or somthing. There is some power to be gained from this. Get in any four wheeler mag and give some of the ads a call. There will be a number of them that can hook you up. I deal alot with rockymountainatv.com but sometimes run into problem getting stuff for older trikes. The place I generally deal with for the older stuff is called J&M Supply out of Memphis TN.
um.. can i go high comp without boring?(spelling??)
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
If you measure the cylinder and it is within the specs to replace it with a piston of the same size you can. You will need to have it honed and make sure you have the proper clearance between the piston and cylinder wall before you just throw it together though. Wait until you get the new piston and then carry it to someone with the tools to hone it and have them fit the cylinder to the piston. Be sure the know what they are doing also. Go ahead and pick up a repair manual off ebay and do some reading. It might even help you. Sometimes mechanics will screw you if they think you don't have a clue what things should cost or how anything works.
ya my dad know all this stuff. well what iim really asking is do i really have to get it bored? how much is that usally?
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
Boreing generally runs from 45-60 bucks. It depends on the labor rate the shop you go to is charging. Generally they charge for 1 hour. You will need to have the piston before it can be bored.
alrighty het u got a screen name? mine is vartiak1114
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
I am a newbie here and I hope this doesn't sound to stupid, but, what is a screen name. I promise I am better with engines than I am with a cpu.
o its not on the web site its like aim(aol instant messager) or like yahoo instant message
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
wildman12300.
I havent used it in a while so I don't know if still exsist.
you can get pistons not just for the stock bore and 12:1 but the inbetween compression ratios alos so keep that in mind and that a 12:1 needs race gas or a octane booster. A compression ratio that doesnt need race gas is alot cheaper in you gas prices to.
ya i dont want it to be hard to start. ne other places i shoudl look or brands to get?????
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
