Results 1 to 11 of 11
Thread: free air R boost bottle
    Jun 2002
    Mississippi
    2,552
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Yamahammer490's Avatar
    Yamahammer490 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    Holic was - and he's already the high bidder.
    CURRENT RIDES:
    1988 Tri-Z 350 Twin
    1985 1/2 Tri-Z
    1984 IT490
    IMPORTANT: Those of you with an overwhelming fear of
    the unknown will be gratified to learn that there is no hidden message revealed by reading this backwards, so just ignore that Alert Notice from Microsoft.
    Jun 2003
    South of Rochester, NY
    3,471
    How does this thing work anyway? Will it fit on a 82 250R?
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Jun 2002
    Mississippi
    2,552
    i see no reason it that is should not fit. i dont think they really do much for performance.
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
    Nov 2002
    1,189
    They lower the crankcase pressure a tad, and may be able to hold a little more air and fuel mixture. They don't do much, but you should see a slight gain.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Aug 2003
    254
    A "boost bottle" is technically called a Helmholtz Resonator. It is supposed to help absorb the pressure wave sent back through the carbs, improving throttle response and overall carburation at the lower end of the rev range.
    Whether or not, and how much, they work is subject to a lot of debate and there are a lot of variables in boost bottle design. The size of the bottle and length of the hose must be correct for the bottle to be "tuned" to the size of the engine. For example, if you took the boost bottle of a Tri-Z (which is about 3"x3"x4") and replaced it with a 2-liter soda bottle, the engine would run differently and, in theory, have a different "flat spot" in the power curve. (Assuming it ran at all.)
    I guy I work with had a Tri-Z and removed the boost bottle because it cracked. He just plugged the hole in the manifold and remove the tube and bottle. He said the engine ran like crap until he found a replacement.
    Sorry for the long lecture. I'm a recovering mechanical engineer and just can't help myself sometimes.
    CURRENT RIDES:
    1988 Tri-Z 350 Twin
    1985 1/2 Tri-Z
    1984 IT490
    Dec 2002
    749
    The engine ran like crap because it was getting to much fuel. After putting on the boost bottle you must rejet. Its somewhat like putting on a reed spacer or having a longer intake tube. You could put a 2 liter bottle on but the carb jet would have to be huge. The bottle also helps getting the fuel and air mixed more. Its like the old motorcycle flattrack racers with the real long intake tubes where the carb was about a foot from the head. The air and fuel got a spiral pattern going and whenever that spark hit: KABOOM.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    Aug 2003
    254
    Quote Originally Posted by 3WheelsForever
    Yes, you are right. When you change the configuration of the intake you need to rejet. The same holds true when you add a pipe. The flow characteristics are different so you need to change jetting.
    I wish I would have known he was taking off the boost bottle and spent a little time trying to make it run right. I've always wondered just how much a boost bottle adds but that question has a lot of dynamics.
    CURRENT RIDES:
    1988 Tri-Z 350 Twin
    1985 1/2 Tri-Z
    1984 IT490
    Aug 2002
    Jamul, CA. near San Diego
    1,605
    did someone say TURBO 500?.........hahahahahahaha
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    all you free air R and other single cylinder 2 stroke guys, do know that any brand yamaha blaster boost bottle will work dont you? same thing, and you can get all sorts of different brands. its not like a custom fit thing,, except for like 2 cylinder models where there is 2 hose connectors on the bottle.
    Ithaca, NY
    2,596
    Quote Originally Posted by 85ATC250R
    Yea, but I am looking for old aftermarket stuff, whether it works or not, it just must be in good condition, heck I'd buy a vintage answer roost boost and throw it on the R just for the heck of it, and Hammer, that was informitive, thanks. Helmholtz regulator, eh?? LOL thats cool.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
