well dont pull the head.. just run a compression test and see where you are... also alot of people just run the b8es plugs in those.. including myself.. as far as everythg else.. you should to get a manual.. to answer the alot of the questions that pop up..
how does it run? reeds should be replaced annualy.. if you ride ALOT.. are they closing? chipped? you should replace yr gaskets when your pulling the reeds.. also what other mods? pipe? air box? carb? where you ride? once you jet it in.. no need to change, unless your riding location changes.. so no just get some jets, and 6-10 plugs and read them.. see how it runs, check the plug colors..
Ride it like you stole it! And never look back! They are too far behind to see!
