what kinda gas do i gota run with a 10.25 comp. can i use regular?
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
87 will run but not great ..... 92 will run much better.
It's best to run 92 in your bike even if it is stock. In my opionion octane helps alot. My 85 250R is pretty much stock and I run 93 octane. When I go to the dunes I mix 93 and 110 50/50 and it makes the bike run much better. It seems to improve the throttle response alot the last time I was there I ran atleast 10 gallons through it because I was there a whole week and I had no engine damage so I think it is ok to say it is safe.
2000 Banshee: Modded out!!!
1985 ATC 250R: Bone stock but not for long.
1984 ATC 185S: Modded out!!
1979 ATC 110: Stock execept fork extentions
1984 ATC 110: Same as above
