what kind of oil:fuel ratios do people run on 2 strokes. what brand? I personally run a 40:1 mix with spectro full-syn . it seems rich, what do you think?
For one thing, i really dont care for spectro products. I run BelRay myself. Alot of others like maxima, klotz, etc.
For synthetics, 50:1 is a good ratio. I know of desert riders who run 100:1 ratios and lower.
Synthetics are a little expensive for me, so I run the real stuff. 32:1 is a pretty good baseline ratio. Some guys run 45:1, and some lower. I personally have never ran less then 32:1 in my machines except for when I first put together a motor.
Oh, and welcome to the board.
Bel-Ray MC-1 at 50:1.
Motul 800 Synthetic mixed 36:1 with AV-GAS or VP dirt bike race fuel .
You should be running that spectro at 50:1. Any good synthetic or blend should be ran at 50:1.
I always run 32:1 in everything I have. I mean it is better than running lean and I have yet to foul a plug, so I think it is the best mixture,for me anyhow. I usually just run the cheap $.79 a can stuff from the local market, I know I'll prolly hear it over this, but I mean there isn't much use in running the expensive in my book, It has serverd me well for a good while. I just got a 91 RM 250 Friday, and I finally started running Klotz,it is good stuff. I used to run Golden Spectrum a while back, but I personally have not had a problem with any of it as long as it is ran at 32:1.I like the smell of the Klotz though when it is being burned.
ATC350X,ATC70,1991 RM 250,XR500,TM400,TS400,Foreman400 4X4,Polaris 425 Magnum,ATC 90, 1982 175,1973 Honda Trail 90,1980 CR80,1981 CR80,
I run spectro at 50 to 1 ....... In my R
1985 250R Selveys port job and pipe
1985 70 piped for lil'freaks
2001 TRX90
ATC 90+250R+BEER= Drag Bike
1984 ATC70 Pit bike
1984 110 for sale
What about Amsoil?
-'86 ATC 250SX: No longer mine...Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
Hondaline blue lable non synthetic for me in my 250R, TriZ, Tecate, KDX200 mixed at 36:1.
I also run Hondaline when i have the money and can find it. Pretty good quality oil.
I believe in Maxima 927 Castor and 100 octane Aviation fuel mixed @ about 32:1. Has a nice aroma about it, and it's always worked well for me.
A good rule of thumb that I use is when using cheaper oils that you need to run @ 32:1 to bump up your main jet size a size or two. This helps make more power with richer fuel. I run power plus @ 50:1 and it has the best bubble gum aroma to it. I haven't heard anybody on this board ever talk about power plus-- is it avalible in your areas??
1985 YAMI TRI-Z RZ350 POWERED
1986 250R STOCK WITH FMF & K&N
1986 TRX70 mini golf cart
TRY AND CATCH ME.....................I HAVE MO CYLINDERS THAN YOU !!!!!
i use power plus, smokeless! its great, especially at 50:1. i use it in all of my trimmers blowers and stuff
Spectro, Bell Ray, Torco and cheapo Havoline on a Sunday. I never had a seizure or excessive fouled plugs. Seems like alot of different brands all work, Hmmmmm.
how much is synthetic compared to the regular stuff?
85 200x - Torn apart
