want to put a 14 tooth sprocket on my 85 cant get the chain loose. anybody have any tricks for doing this.
85 atc 250r;
PSI porting & head mods
fmf pipe & silencer
boysen rad valve & reeds
38mm air stryker
The axle carrier won't turn in the swingarm? Have to ask, you loosened the the hex head bolts that clamp the carrier right? You can try taking the bolts all the way out and pry the clamps apart a little with a big screwdriver. Best way to do it is pull the axle out and then beat the carrier out with a block of wood and a big, then grease it up good and put it back in. Course if your chain is too short none of this will matter...
1985 ATC250ES
1985 ATC250SX
1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
1985 ATC70
2008 CRF230L - Dual Sport
2016 TRX500 Foreman Rubicon Deluxe
I can only get a 14 tooth to fit when the chain is worn out(stretched). There's just not enough adjustment.
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
ya the carrier is stuck in the swingarm.the bolts are loose and all that stuff. looks like i either pull the axle or stay with what i have until the sprokets are completely shot.
85 atc 250r;
fmf pipe & silencer
38mm air stryker
