Results 1 to 8 of 8
Thread: Winches and snorkels
    GreyhoundRugby is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Indiana
    196
    How would i go about getting a winch and snorkel on my 85 250sx. I got alot planned for it i already have a bore kit and im going to make my own pipes because its hard to find commercial sx pipes. BUt if you have a link to aplace that sells those two things itd be nice
    Oswego, IL
    1,858
    for the snorkel you can get some rubber tubing the size of your carb and just use a hose clamp and connect that then run it along your frame and out the back then have it come up and then put a big air filter on the the end and have it stick up about a foot or 2 above your fender. and the winch if u got a front rach im sure u can make somthin up. damn i want a rack for my 350 on the front and back i want one on the front so i can put a whinch on there. well it is my 200x but its got a 350 front end.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Jun 2004
    Indiana
    196
    sounds like a nice trike only problem is i dont have a front rack but i can pry make one. i just dont want the pull of the winch to rip off anything that i attach it to but i think i can do it.
    Jan 2004
    66
    I just installed a winch on my 85' Big Red. It's a 1500lb cap. Works great. Found the biggest, muddiest hole I could and launched in their to test it out. I had mud up to the head. Pulled'er out no problem. We have light machines so that helps. As far as your front rack is concerned, you might have to make one if you can;t find an OEM rack. I made 2 plates out of 3/8" galv. steel and sandwiched them between the rack. Than I took a piece of 1/4" steel and attached the winch to that, than that peice on to the the 3/8" top plate. I was worried about the rack bending, that's why I opted for the sandwich effect with two pieces. Adds a fair amt of wieght to your front end, though. I could only notice it going over whoop-D-do's though. Felt like the rear end wanted to lift a little bit. Minor issue considering I no longer have to push and pull my way out of the slop. You also have to centre the unit somewhat on the rack, in order to distribute the weight evenly. You cannot have the wire running straight with the centre of the bike. The motor side of the winch is heavier, so it's got to be off centre a little bit. Mine is not perfectly balanced - if I put the bike on a lift the wheel will pull to the left slightly, but it's a good compromise.
    I am also considering snorkeling this thing. Shouldn;t be hard. Couple pieces of PVC, some hose and clamps. For the exhaust, I'm thinking of just tapping the spark arrestor and fitting it with a pipe with a 90 degree angle.
    I ahve seen pics before of a snorkelled big red, but I can;t find them now. I'd also like to make it so there is a quick assembly and disassambly of the unit - so as to make it as versatile as possible. Any one have other ideas to help?
    Jun 2004
    Indiana
    196
    Seabass think i could put the winch on the back bar? (dont know the name of it sorry)
    Mar 2004
    Saint John NB, Canada
    146
    if i were you i would attach the winch on the frame not on the front end because if you get really stuck and start to winch it might break your front end off
    "And I bled out of here, and here, and here and here.........."
    '84 200M-Cobra pipe-sold
    '99 honda 300 fourtrax-2 inch lift, Bearclaws on ITPs
    1981 honda 185s-Ole Smokey! :
    1987 Honda 250x....well in theory
    Mar 2004
    30
    You're gonna want to put that snorkel on the front, not the back like a think someone mentioned. If you put it on the front, when things get a little hairy, you can raise the front end into a wheelie to keep the snokel above the water line.
    modded 01 mojave
    Jun 2004
    Indiana
    196
    Im gonna bend up some metal this weekend probable skrew rubber i have to make it more difficult than its gotta be
