As far as I'm concerned, the premix ratio is set by whichever type of oil you buy. If you use cheap stuff, you should keep it 20/1 to 32/1. If you use Bel Ray that recommends 40/1, do it. If you use $10 a bottle Klotz that recommends 50/1, do it. The higher technology of the oil, usually the higher ratio you can use. But once you find one the bike agrees with, don't go changing it just to be changing it.
1985 ATC250ES
1985 ATC250SX
1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
1985 ATC70
2008 CRF230L - Dual Sport
2016 TRX500 Foreman Rubicon Deluxe
