Results 1 to 7 of 7
Thread: honda 125
    Mar 2004
    Belton Texas
    132
    honda 125
    are they good atc. haw do they compare to my 200 they in an ad in the paper and it is 2 for 600 are they fast and will they tote me around 200 lb dude
    three wheeling for life
    rides:
    83 honda atc 200 Sold for $400
    saving up for tecate 250R tri Z ao 350X
    Mar 2004
    Belton Texas
    132
    anyboody know
    rides:
    125m's
    I have owned 3 of them and love them! I am 6'1" and 175lbs and it pulled me around great. I say if the 2 125s are in good condition (plastic, motor, tires) and for that price thats a great deal. All of mine that I have purchased are in between the price of 100-400. The 125 will feel alot slower and will top out at a good 35-40mph in hi range. Well this is just my 0.02 cents! Peace
    Bigred
    My 3 wheelers
    1985 honda 350x - Durablue axle +4, supertrapp exhaust, k&n filter, clarke tank, Answer bars, twist throttle (want a thumb), and scott grips, Just Put in a new cam and rocker arms! New hauler extremes 20x10x10 8 Paddle!
    1985 honda 250es bigred - new tires and cobra utility exhaust (sounds awesome and gives it a little more grunt)
    1984 honda 200s - stock, no baffle, needs work
    1982 honda 200s - stock, almost mint
    Real men ride red . . . Bigred
    I had a 1985 125m and I found that it was a great little trike and it hauled me around pretty good(185lbs),I would go for it.
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Mar 2004
    Belton Texas
    132
    thanks for the input
    rides:
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    I had one and like it quite a bit. Im 6'3 280lbs and it carried me just fine. It has a high and low range sub tranny. The only weak point I know of is the tranny. There is a arm under the clutch cover that holds the trike in gear. This arm is bad about shearing loose from the case under heavy load. Mine did it, and I was told by 3 salvage yds that was a common problem. The 110 didnt have that problem. But who cares, the 125 has electric start.
    ClayW
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    a weak point on the 125 I had was the front engine mount(triangle shaped mount with 3 bolts in it that connects the engine to the frame)but I did do a lot of wheelies with it and it did take a beating so that maybe why it broke but the good thing is that the mount is not discontinued from honda
    85 Honda 200X
    88 Honda CR 125
