Results 1 to 13 of 13
Thread: gas tank rust... how to clean?
    82-8250R Guest
    is there a way to get rust out of the tank?
    Power_Ram100's Avatar
    Power_Ram100 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    Kent, Washington
    152
    Talking clean tank
    I used about 60 pieces of PEE gravel. and put them in the tank with some degreaser and shook the tank for about 15 min that took care of most of the rust. then i rinsed the tank with water. I had alot of rust in my tank. But make sure you get all the PEE gravel pieces out of your tank.
    Washingtons Crossing, Pa.
    2,977
    Quote Originally Posted by Power_Ram100
    ... very interesting and original.
    82-8250R Guest
    anyone else on this? ive heard there was some sort of liner that can be applied to the inside. but dont know what it is.
    Dec 2002
    deer park, texas
    2,336
    i have always used por15 gas tank liner. it comes in a kit that will have chemicals to remove the rust, prime it then the por15 coat which will last forever.
    eh_tee_see's Avatar
    eh_tee_see is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bristol Bay Alaska
    295
    pee gravel? what in the name of christ and everything else thats holy is that?
    The below sentence is TRUE.
    The above sentence is FALSE
    82-8250R Guest
    thanks i found some stuff called kreem thats a 3 step process that should work
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    Please let us know if it works out for you.Thanks
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    Nov 2002
    1,189
    I've used small chain also. Works great. I'm talking chain like the stuff you use to pull something, not drive chain. Pee gravel is like little round pebbles. Regular driveway Gravel works good, since the sharp edges get off the rust. Just make sure to clean the gravel good. (get the dirt off it!)
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Nov 2001
    B.C.
    933
    PEA gravel is small size gravel....the size of peas!
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Cincinnati, OH
    3,289
    i take my to raditor shop and have it diped and coated! 25 bucks if i take like 2-3 takes but for one its 40 bucks and i dont have to mess with that crappy tank liner kit that cost what like 20 30 bucks!
    May 2004
    SOuthen CALifonia
    138
    I used muratic acid. Poured it in...shook it around...let it sit for about 30 minutes, then tilted the tank on its side, then the other side etc, then rinsed it and sprayed a little WD-40 in there and looks like new inside!
    jsut be careful not to breathe that stuff in. Oh and for 2 gallons its only like $8 at home depot. Also, take the petcok off and tape up the hole with ductape.
    Good luck!
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    Quote Originally Posted by Mobular
    LOL...pee gravel is what happens when u pull over on the side of the road n take a leak.
