Results 1 to 11 of 11
Thread: CR Head Gasket on 250R?
    Jun 2004
    Oregon
    1,782
    -=cr Head Gasket On Atc250r??=-
    I've heard from many people that using a CR250 HG on a ATC250R gives it more power..Ive never really seen this or actually tried it..Im wondering if anybody else on this forum has and what are the pros and cons to this..Any info would be great thanks
    Oh !! I wanted to tell all of you that after tearing my 85 R down to the frame and building it back i somehow lost 2 links to my chain LOL..I know they didn't fall off!! i was really confused when i ran into this problem,and it fit just fine before the tear down haha!! This is my first time doing this to my R so im sure i fuked something up along the way!! LOL :P ...................Pics to come soon..
    Michigan
    1,220
    try rotating your bearing carrier, you may find those 2 links
    Jun 2004
    Mississippi
    83
    the CR head gasket is a direct replacement and it works great. You really feel it down low.
    2000 Banshee: Modded out!!!
    1985 ATC 250R: Bone stock but not for long.
    1984 ATC 185S: Modded out!!
    1979 ATC 110: Stock execept fork extentions
    1984 ATC 110: Same as above
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    it goes right on, and it provides a little more low end, nothing major, and not really worth the cost of the cr headgasket, thats why i just modified the stock 85 gasket.
    Dec 2003
    Utah
    55
    I run an '89 CR gasket on my trike. It makes a little difference. I thought that $18.00 was not that big of an expence. Just my opinion.
    Upstate NY
    2,665
    yes, true, 18 dollars is cheap enough for a little more power, but,, why bother going through the dealer and all that crap (just so you know, dealer up here is a major trailprotrailprotrailprotrailprotrailpro and takes like a month, may be diffrent if you have a nice dealer) i just take the stock 85 gasket, its 3 layers, remove the top and bottom layer, and just run one single layer, same thing! cost= $0
    Las Vegas, NV.
    2,490
    Quote Originally Posted by 85ATC250R
    Except for the cost of the 85 250R head gasket.
    Houston,Texas
    1,044
    So,if I put 2 gaskets on a 2-stroke, it would give me more top end? Or does it only work one way?
    And is it the top or bottom head gasket that makes the difference? thanx
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Jun 2004
    Oregon
    1,782
    you can actually do that? you wont burn anything up? And if you do will you need to rejet and add a after market pipe if your still running a stock pipe that is??
    Upstate NY
    2,665
    red rider- well,.. usually.. someone who has a 85 250r thats running.. they have a headgasket on there engine...
    Jun 2004
    Oregon
    1,782
    250R, Whats the best year CR gasket to buy?89?
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
