I want to get a nice Sportish quad(No Banshee's or 400 ex's thought) like a 300ex, or a warrior. Which one is better? Also, what are the pros and cons of a Tecate 4?
well the warrior is better than the ex, but i say get a z400
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
Does it have reverse? I think I'd rather have a reverse on one that I get.
the z400 has reverse. I also wouldnt mind having one myself!!! But White though!!
My 3 wheelers1985 honda 350x - Durablue axle +4, supertrapp exhaust, k&n filter, clarke tank, Answer bars, twist throttle (want a thumb), and scott grips, Just Put in a new cam and rocker arms! New hauler extremes 20x10x10 8 Paddle!
1985 honda 250es bigred - new tires and cobra utility exhaust (sounds awesome and gives it a little more grunt)
1984 honda 200s - stock, no baffle, needs work
1982 honda 200s - stock, almost mint
Real men ride red . . . Bigred
out of the choices you listed i would get the 300ex. it has no cons at all. pros-honda, reverse, parts are easy to find
1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
1984 Honda 200ES
198? Yamaha YT60 Tri-Zinger
TrikeFest '04 & '07 Survivor
I would get the 300ex too. They are bullet proof pretty much. ive gave mine hell. Just have to do normal stuff like oil chaines, chain and sprokets and brakes. Thats all ive done to mine.. still starts right up and it runs good. Warriors are good bikes too. My nieghbor has one. Alittle heavy to me. I cant throw it around like i can my 300ex. His is about 5mph faster on topend but i can take off alittle bit faster. Now with a 14t front sproket i can stay with him sort of.
06 TRX450r , 85 ATC250r, 01 TRX300ex, 84 ATC110
88 Mustang GT
... well, one "pro" is about 20 mph over the other two.Also, what are the pros and cons of a Tecate 4?
... one con, one word "maintenence".
It really depends on your size in this case. Both quads are bullet proof, uber-reliable, fun sport machines. The difference will lay in if you're over 6ft tall, the 300EX will be cramped for you. If you're under 5'5', the Warrior will be too big. Same goes for weight. After that some other differences are: The 300EX will out handle the Warrior in most cases but the Warrior is faster in most cases. The after market value of any year 300EX is usually much higher than a Warrior of the same year. While this means you can get a good deal on a warrior, you will lose out on when you go to sell it. (the 300EX is a better investment). Other minor differences include: Hondas link-less shifter is much better than the Warriors unit, the carb on the Warrior is easier to work on for cleaning, the 300EX's shocks can't be rebuilt, the Warriors can. The Warriors two valve engine is easier to adjust the valves on than the four valve 300EX. The 300EX is a lighter machine by a good 20 - 25lbs.
Well thats about it ..... oh, one more thing, why rule out the Kawasaki Mojave 250 or the later Suzuki LT230/250S quadsports?. All great machines. good luck!
how much $ do you have to spend?
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
get a warrior, the 300ex is slow
The maniability of the 300EX is really good...it is pretty nice, performs good, and it's really fun to ride! I have never ridden a warrior yet, but I heard they are heavier than the average of the other quads.
Go big or go home!!
Current rides:
'85 250SX - Sold...I had no choice! Need money...
'93 Fourtrax 300 4x4 (27" Super Swampers)
'95 Yami VK 540
I suffer from that malady myself .... lolmaniability
i think that means you can be a maniac on it and not hurt it??
1984 Honda 200ES
I have never ridden either quad, but all the reading I do does NOT speak well of the Warrior. I guess Yamamha never improves anything and they have an archaic air box system and chain tensioning system. Honda on the other hands makes minor improvements every year until they get their stuff perfect.
Honda
86 350X - Full Restomod
85 250R - Legend
85 Big Red - Clean Original
85 Big Red - Custom
Not Honda
85 Yam Badger 80 - Kids
99 Pol Sport 400 - Got it FREE
yr right... the warrior is kinda blah after a while.. what you want to do w it? just cruise? beef it up?
Ride it like you stole it! And never look back! They are too far behind to see!
BUT, the Warrior is being replaced by the Raptor 350. Better suspension, tires, pipe, new designed plastic. It looks awesome, check the new Dirt Wheels for a test.
1985 ATC250ES
1985 ATC250SX
1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
1985 ATC70
2008 CRF230L - Dual Sport
2016 TRX500 Foreman Rubicon Deluxe
