Results 1 to 8 of 8
Thread: 200x carb on 200x ?
    thehickfarmer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    200x carb on 200s ?
    would this be a direct bolt on ? what is the MM diffrence between the two ?
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    Yes a 200X carb would fit on a 200X. Or did you mean a 200S? 200S is a 22mm as the 200x is a 24mm.
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    i mean will it fit on the intake.. beacuase i think i will be doing this. will i see a incress in anything???
    Hampton, Virginia, C.S.A.
    2,664
    i think he means puting a 200x carb on a 200s i was gonna do that but i couldnt find a cheap 200x carb
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    yes thats what i ment. sorry. 200x carb on 200s. so will something change to the better ???
    anyone know what will improve ???
    Mar 2003
    Barnesville,Ohio
    2,298
    it'll use more gas but have more power and better throttle response
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    May 2002
    610
    Usuall adding a bigger carb will reduce throttle response. Going smaller will increase lower end power and going bigger will increase high end power. THere is a happy medium in the middle somewhere. Using a bigger carb will only help horsepower if the carb is a limiting factor on the engine.
    Sam from Florida
    1985 BIGRED $ 200X
