Results 1 to 8 of 8
Thread: 185s won't 185start
    Jun 2004
    South Mills, NC
    24
    185s won't 185start
    my 81 185s won't start. i just put on slightly used coil, cdi box, pick-up sensor, fuel lines(new), spark plug and then i cleaned the carb, and i now have spark. i don't have a compression tester with a small enough plug but i can put my finger over the hole and it feels pretty good. i'm getting gas to the carb but it doesn't even try to start, sputter or fart. i have retarded the timing and still nothing. it doesn't even start with starting fluid. i got it flooded a few times and each time i took out the plug, cleaned it and let the cyclinder air out. it's a pretty good spark at the plug but it acts as if it doesn't fire once i put the plug in. the compresion releases when i used it, but i ussually don't use it at all. i'm sure somebody else has had this problem as getting help on this site is easy.
    thanks
    The biggest fish in the river gets that way
    being fast and never getting caught.
    Rides:
    83 atc70
    84 atc70
    85 atc70
    81 atc185s
    92 Kawi Bayou
    86 trx125
    71 mx360 yama
    71 rl250 trials suzi
    72 rv90 suzi
    smokey's Avatar
    smokey is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    ravenwood MO
    221
    my atc200 did that so i hooked it to my 4-wheeler and pulled it about 100 feet and it started.
    Jul 2004
    Minniesota
    115
    the timing might be off
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    I also had a friend who had a 185, it wouldn't start, so he towed it with a truck, and by jove, it never started again, timing was off, valve dropped, shattered the piston, and cleaning metal shards out of a bottom end is not worth anyone's time. Towing to bumpstart a bike when it stalls and won't start again? good idea. towing to bumpstart a bike that just doesn't run for an unknown reason? bad idea.
    There are things called voltmeters, that can be used to test for electrical probs, clymer manuals show how to do the tests.
    have you checked the timing, and actually know how to check it?
    are you sure you gapped the plug?
    have you ever checked your carb or cleaned it?
    also, a big thing i usually find with my 185, is the plug, try a new one. mine used to foul the plug, i'd clean it really good, stick it in, nothing, try again, nothing, new plug, schwing!, fires right up
    good luck bud, keep at 'er
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Apr 2004
    International Falls Minnesota
    546
    Sounds like your timeing is off 180 degrees. Redo the timeing i but thats your problem
    eh_tee_see's Avatar
    eh_tee_see is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bristol Bay Alaska
    295
    sure all those are valuable suggestions but when you know that you have compression, spark, timing, and fuel yet it won't start; i'll bet you anything your valves are too tight. It's happened to me twice. And the valves/ rockers in the 185s/200s engines are crap too say the least. So loosen em up a bit and see if that helps.
    The below sentence is TRUE.
    The above sentence is FALSE
    eh_tee_see's Avatar
    Bristol Bay Alaska
    295
    BUt on another note; if you're not using the compression lever to start it, it could be that you need new rings. and you're plugs will foul easy with bad rings
    Jul 2004
    Backwoods, Maine
    18
    Exclamation
    If the keyway on the end of the camshaft has been apart, it may be 180 degrees out. So you would think it was firing on the combustion stroke, when it was actually firing during intake (not good). Everything will look correct timing wise. This is tricky. On the end of the camshaft in the cdi cover,Try taking the magnetic pickup apart from the advance weights, and turn it 180 and put it back in. This one baffled me for almost an hour once. maybe this will help I wish you luck.
    mudpuppy.
